メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、2015年4月10日に発売されたGalaxy S6は、Galaxyラインにおける次世代フラッグシップモデルです。曲面スクリーンバージョンはGalaxy S6 Edgeとして知られています。
it says no sim or sim error
I have the same problem. When placing a call it says no sim or sim error but data works, help please.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
11 件のコメント
Check and let us know IMEI availability of the device by *#06#. no need to put IMEI number here. just answer yes or no
さんによる
yes. IMEI is available .
さんによる
no, there is NIL imei please tell me method to solve it
さんによる
I also have the same problem it said insert sim card and can't access the network setting as well but I already insert it the sim works in another phone the same model samsung s6 I took it to maintenance shop they said there is no technical failer to it it ok but they can't fix it as they don't understand the problem by the way it works another country sim card
さんによる
i was using sim card in s6 and then i rest factory data after this in start it show sim card crash but i can use this sin another mobile and any other sim also not working in s6 its show no sim card
さんによる
6件以上のコメントを表示
コメントを追加
4件の回答
最も参考になった回答
The problem usually has to do with the copper connectors on the sim card getting dirty. To fix it just follow the steps.
  • 1 Pop out the sim card by putting a small paperclip or pin into the tiny hole on the side of your Phone. Push hard so it pops out.
  • 2 Take the card out of the little tray. Remember how it looks when it was in so you can put back correctly.
  • 3 Put some rubbing alcohol on the end of a Q-Tip.
  • 4 Rub the copper side of the sim card thoroughly. Wait a minute to let it dry.
  • 5 Stick the card back in the slot.
  • 6 Problem should be solved.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Cleaning the SIM didn't work for me. I also blew out dust and tried removing and reinstalling the SIM a dozen times. I'm in Canada and I just happened to have an AT&T SIM that I use in the USA. Trying that SIM didn't work either.
Even thought I throught my phone could not be fixed. I took it to a Bell Mobility store where I live in Canada and they wanted to try a new SIM. They said mine looked worn.
The new SIM WORKED!!!
Maybe the AT&T SIM will also work, but only in the US.
さんによる
コメントを追加
sim card not work and pta proweaif data not show plz sim not wort problem
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try to reset network settings by going to your phone setting then open backup md reset nd reset network setting it will help you a lot
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it is saying that the SIM card is error
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
emmanuelfranco さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 25,819
