メインコンテンツにスキップ
iPhone 4のCDMA版モデルです。修理はそのままパーツに作業をしますが、フロントガラスとLCDはユニットで交換しなければなりません。16もしくは32 GB / Model A1349。
295回答 すべてを表示
No Display and Repeating Charge Chime
Hello, I have 2 iPhone 4's on Verizon. I wanted to swap the screens on them since one is in locked and the other one is shattered. After a very long process of lost screws and frustration I finally have the good screen on the good phone. The only thing it does now is show up in iTunes and keep making the charge chime. I have put the other board in the housing and it does the same thing. I have even tried the cracked screen on both boards and the same thing happens. I would really appreciate it if you could help me out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
Sounds like either board damage or both the screens got damaged from improper installation.
さんによる
I have the same case, except my screen is shattered. The screen worked like that though, and my phone is a little rough, any fixes anyone?
edit: havent replaced the screen yet, its just like this
さんによる
コメントを追加
1 件の回答
Very unfortunately, Dylan, your 'good screen' is probably bad. Exactly what you observe (no display and repeating chime) indicates a broken or missing screen. You have my sympathy: replacing iPhone 4 front/screen assembly is onerous. Too I broke an otherwise operational screen, by bending its cable.
See Wiki page: iPhone endlessly repeats the "power supply accepted" sound or vibration.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dylan Mclaughlin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 15
今までの合計 292
