32 GB iPod Touch smashed screen/digitizer. Replaced; LCD now dead.
My husband dropped his iPod Touch (32 GB) while working out on treadmill. Smashed screen and digitizer but could still see the LCD homescreen and notifications. I replaced it with this http://www.amazon.com/gp/product/B0049PQ... which is a pre-assembled glass/digitizer/chassis bezel. This seemed to go well, but now there is no picture at all. I thought perhaps it needed charging so I plugged it in for several hours - still nothing. When I plug it in, it does "sound" like it's connecting to a charge, and when I plug it into his iTunes account it says it is updating his iPod. Still nothing shows on the iPod screen. Please help!
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Looking closely, I see that under the ribbon connection in the upper left corner of the iPod Touch screen, one of the "teeth" on the connection is missing. I do not know if this is part of the motherboard and/or if this missing tooth basically makes the iPod unfixable. Does anyone have an answer to this? Thanks!
による
コメントを追加
1回答
選択されたソリューション
During the digitizer replacement you must have accidentally unplugged the LCD. You should be able to reuse the safe opening tools to reopen, plug the LCD back in and snap the digitizer back on (after plugging it in as well of course) follow the instructions found within ifixit and you should be back in business im short order.
この回答は役に立ちましたか?
スコア 2
コメント:
Thank you so much, Marc, for your quick response. I have to figure out now how to plug in the LCD. Do you have a link for that? Bless you!
による
So I guess this would be the same for the 32GB 3rd generation then, right? Thanks again.
による
Pat O since yours is listed as a 3rd Generation, here are the instructions.iPod Touch 3rd Generation Display Replacement and yes this goes for all 3rd gen regardless of storage space 32 or 64 same instructions. Good Luck
による
Thank you so very much!
による
表示する 4 他のコメントを
コメントを追加
回答を追加する
Pat O さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,077
