battery contacts points missing in cover
how can I replace the battery contacts points in the cover
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@fasteddywilson, edmund, Normally the battery door assy would be replaced as it will have the contacts molded into it I believe. Below is a guide that will show how to disassemble camera to access battery door hinge pin to enable changing of battery door. Also a couple links to replacement battery door assy. which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 16
過去 30 日: 23
今までの合計 615
