メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG X Powerは2016年8月に発売された4G LTEスマートフォンです。このモデルは16 GBのメモリとオペレーションシステムとしてAndroidを搭載しています。
My touchscreen not working
I had my phone in my pants pocket and it had a case on it and it rained a little bit got my pocket wet a tiny bit and after I went on lunch for work my touchscreen wont respond I reset my phone but I cant click next to set it up
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
1 件の回答
try taking the phone completely apart, and checking all the connections and letting it fully dry out if it isn't.
make sure the touch screen is receiving power from the charging port. Let us know if this helps or if you find something, good luck!
You have to do an advanced hardware reset by first removing the battery for 30 minutes. Set a timer. After 30 mins, replace the battery and hold the volume down button for another 15 minutes. Set a timer. After 15 minutes, release the volume down and press volume up button rapidly 3 times and then immediately remove the battery again, this time, also remove the sim card. Wait about 30 seconds, and replace battery and sim.
When you power the phone back on, you should get a prompt asking you which hardware component to update., Select "screen sensor" by scrolling through the options with volume down and select it by pressing volume up. The phone will now reset the "screen sensor" hardware data and download the newest hardware update for your phone.
Screen should now be fully functional.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Unfortunately i cant take the battery when i try to it bends the nattery
さんによる
I have this same phone. You can't take the battery out.
さんによる
never heard of an "advanced hardware reset" ...
will try it now and report the result
さんによる
Well, it's like i thought, not working
さんによる
コメントを追加
回答を追加する
Jango DarkWind さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 25
今までの合計 6,043
