What should I do if I spill juice into the earpiece?
The Earpiece works but I just what to know if there is anything more that I can do?
The device is the LG Nexus 5x.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, clean it. Clean it with 90% or better alcohol, to avoid further corrosion, which could further damage your device. Use the below guides to do so.
Hope this helps!
ガイド
難易度:
難しい
1 - 2 hours
ガイド
難易度:
中レベル
25 - 40 minutes
このアンサーは役に立ちましたか?
I don't have 90% alcohol... Is there any alternatives?
No. Buy some. 90% just means that 90% of the bottle is alcohol and the other percentage is bitterant/additives. Clean ASAP.
Do I need to take the phone apart to clean it?
Yes. That is what those guides are for.
Just out of instead, what would the damage be like if I just left it alone?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 78
