メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Genioは、Nestlé(ネスレ)のコーヒーカプセルシステムであるNescafé Dolce Gustoの第2シリーズであり、Arno、Krups、De'Longhiによって製造されています。ペンギンのような形状が特徴です。
Stoped working at all
My dolce Gusto stoped working when connected to electricity. Light does not even appear
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
8 件のコメント
Does it work when its not connected? When did this occur? How long have you had it?
さんによる
My machine is only 5 months old. In 2 years I had 3 machines
さんによる
Hi got a Nescafé Dolce gusto machine and input a discaler through it yesterday as not running quite so smoothly . Did it and rinsed it through all ok. I went to use it and nothing the red light come on then the green been when it's a constant green unmove the swit h over to hot and nothing happens ? Any ideas
Thanks
さんによる
Have the same problem, how do you resolve it?
さんによる
ive had my Krups Piccolo Xs Manual Coffee Machine for 2 days i used it once now not working, no lights on, cant even take pods out it seems jammed? ive tried different sockets, assuming its not the fuse as its only couple days old, any ideas? please i need a coffee hahha
さんによる
3件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
I think you should check your Dolce Gusto Genio’s mainboard(motherboard) or power port.
Then I think you could fix it.
Have a good day^^
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
looks like that signal form switch (hot water lever) goes to main board, but then what?
Maybe you know where should I start?
さんによる
I'm sorry, I misinformed you earlier.
Let me correct what I said earlier.
I think your Dolce Gusto fuse is broken so it doesn't working.
Here's a link to a YouTube video that tells you how to fix it.
Link : https://www.youtube.com/watch?v=aja0DsBO...
Link for your Dolce Gusto's fuse (SF129E) : https://www.amazon.com/SF129E-SEFUSE-Cut...
I hope you'll be able to repair it.
Have a nice day.
さんによる
ahh thank you for a suggestion, checked my fuses.
But all of them looks normal.
So still looking for my problem
さんによる
コメントを追加
it happened to me months ago and finally fixed it today. The on/off switch consists of a piece of conductive rubber that makes contact with the circuit underneath. In my case the circuit or rubber became misaligned or dirty.
Either way what fixed it was to disassamble the switch side carefully, remove the switch rubber, clean it and the circuit with some q-tips dabbed with alcohol and reassamble all.
Deassembly was the biggest pain.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There are two thermal fuses in the back, above the boiler. Replace them both.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
You’ll have to take it apart.
さんによる
コメントを追加
回答を追加する
Suzan さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 52
過去 30 日: 162
今までの合計 37,990
