メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Battery replacement every 2 months
Hi,
I have an iPhone 5s for now 3 years and a half. The original battery lasted as long as 2 years and a half before dying, so I then replaced it by buying new ones on the Internet.
However, the new batteries I bought (3 or 4 for now) only last 2 months before dying too, so I got to replace them quite frequently.
During the first month of use, they usually work great and have a good capacity, but by the second month, their capacity drop very quickly and my iPhone doesn't start anymore.
Do you have an idea on the cause behind this? Could it be the logic board that is getting dysfunctional and draining the batteries very fast? Or am I just buying bad batteries?
Everything else works fine on the iPhone, I even tried a reset to make sure it wasn't iOS's fault but it didn't change anything.
Should I consider my iPhone dead or is it possible I only got bad batteries?
Thanks for your help :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
10 件のコメント
There are 2 things. Either your iPhone is dead. Or the batteries your getting are very cheap. How much do you pay for the batteries?
さんによる
Usually around 20 bucks each
さんによる
Do you buy them from the same person? Or different sellers?
さんによる
A better question is, where are you purchasing them from?
Have you tried an iFixit sourced battery?
さんによる
Yea, they are 15 bucks at ifixit, for a genuine battery. Your getting ripped off.
さんによる
5件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
I would suggest a genuine iFixit battery.
iPhone 5s のバッテリーの交換方法
iPhone 5s Battery
If this answered your question. Please hit the accept answer button!
iPhone 5s Batteryの画像
製品
iPhone 5s Battery
$29.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
I would recommend using the ifixit battery since they are genuine. You never know with other re-sellers what quality battery you are getting and that is most likely the problem. I have pasted the link below to the part. I hope this helps!
iPhone 5s Battery
製品
iPhone 5s Battery
$29.99
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
@luffy343, the only way to get a real Apple battery is to go to Apple. Any other source is a 3rd party. However, iFixit has accountability as opposed to other sellers.
さんによる
コメントを追加
回答を追加する
Ottomatik さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 143
