メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo DSiは任天堂 DSシリーズの第3世代モデルで、2008年後半に日本でデビューしました。
Top screen faded with flickering lines
One day, I turned on my DSi and the top screen was faded with what looks like interlacing artifacts always going down the screen. Today, I took it apart, cleaned all of the contacts with 70% isopropyl alcohol and I noticed that the screen works completely fine without the shoulder buttons and SD Card slot (back panel) connected. However, when I plug the back panel back in, the problem appears again. I don't have a lot of knowledge when it comes to electronics so I decided to come here to ask how to fix it. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
2件の回答
最も参考になった回答
Hello,
I had the same problem today and discovered, that there are some kind of potentiometers, wich are regulating the screens in some kind. However, you find them if you look on top of the battery. There are two little screws that you can turn to calibrate the screen. The left one is for the lower screen, the right one for the upper screen.
画像
Sorry for my bad english but I hope that this could help you.
このアンサーは役に立ちましたか?
スコア 11
7 件のコメント:
Well, I noticed you posted this back in 2017 so this is pretty much useless.
さんによる
No that worked! Thank you so much I thought it was broken for sure!
さんによる
You´re welkome :)
さんによる
Is this the same for the DSi XL? I opened the batery cover and see two gold screws but no phillips head groove on them. What do i use to adjust them? Thanks.
さんによる
Does this work with the DS Lite model?
さんによる
2件以上のコメントを表示
コメントを追加
I thought those were screws and broke the right one by accident .. is there anything I can do about it?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not sure if this is still relevant. but i broke one of them as well. the way i managed to fix it was by replacing the cable those potentiometers are on. i was able to find one by searching for a DSi SD card slot ribbon cable. i was able to get one for about 10$ for reference
さんによる
コメントを追加
回答を追加する
Rylan Corral さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 20
過去 30 日: 102
今までの合計 13,400
