No orange light when plugged into console
My Xbox One wont turn on and the orange light turns off when I plug the power bar in to the Console
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Presently working on a psu for xbox. Orange light goes off as soon as box turned on. This supply has a 5v standby supply and a 12v run supply. As soon as the run supply was activated, the ps shuts down. Thats because i found shorted transistors in the primary side of the run supply. This needs a competent technician to repair this. Looks like a surface mount capacitor has had some arcing across its surface. Mosfet defintely shorted.
このアンサーは役に立ちましたか?
Can you give a bit more detail which transistors you are talking about that were shorted? Is this inside the PSU or the actual Xbox Motherboard?
This guide might help. Clean the brick with caned air when you put back together. Xbox One パワーブリック (Day One Edition)の分解
And this guide might help to. Xbox Oneのマザーボードの交換
It sounds like a power issue the board might be shorted out so use a multi meter and check all solder marks and traces. Make sure they all get the right amount of power.
If you have any questions or concerns please comment below or email me at walker44805@gmail.com !
ガイド
難易度:
中レベル
30 minutes - 1 hour
ガイド
難易度:
中レベル
30 - 45 minutes
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 29
今までの合計 8,272
1件のコメント
Ya i have tried another PowerBrick and all it was doing was flickering orange
Vimpulse さんによる
