メインコンテンツにスキップ
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
630回答 すべてを表示
Is iPad Mini worth getting repaired after being run over by a car?
My daughter ran over her iPad Mini. It will not cut off, the screen looks fried but it's not cracked. The alarm clock still works and I can still tap it to snooze. The iPad is bent on one side, but looks perfectly normal elsewhere -- I was using an otter for protection; however the top of the otter was not on when it was run over -- just the back.
After reading some of the IFIXIT techniques, I am wondering if I would even be able to open it without issues.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
tulula007 post some images of the "injured" iPad with your question. That way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that
さんによる
Thanks! Am working now, but will as soon as I get home.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Use the below guides to check your battery and LCD. If your battery is damaged at all replace it. Even if it isn't, you should replace it. Because the alarm still works, the motherboard sounds fine. Disconnect and reconnect the LCD cable, and make sure it isn't bent. If you don't feel like doing the somewhat difficult operating on it, it's probably about as cheap to fix it as you can buy a new one.
Hope this helps!
iPad Mini Wi-Fiモデルのバッテリーの交換 iPad Mini Wi-Fiモデルの液晶ディスプレイの交換 iPad mini Battery iPad mini LCD
iPad mini LCDの画像
製品
iPad mini LCD
$49.99
iPad mini Batteryの画像
製品
iPad mini Battery
$29.99
iPad Mini Wi-Fi 液晶ディスプレイの画像
ガイド
難易度:
難しい
2 - 3 hours
iPad Mini Wi-Fi バッテリーの画像
ガイド
難易度:
難しい
45 minutes - 2 hours
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
If its an iPad mini 1st gen, then don't bother. Apple no longer updates this model for iOS. The last update was 9.3.5 and its now up to 10.3, so you are missing a lot.
Getting a housing, new LCD and simply moving the logic board over would cost more time and headache than simply buying a used iPad Mini 2nd that works.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's not worth fixing most likely bad LCD battery and shell and that would cost like $100 you can get a new unit for that and just sell this for 20 bucks on eBay thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tulula007 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 515
