Part of the screen is black
I dropped my dell venue 8 tab and a part of the screen has gone black.The screen is intact but that one part of the screen remains black no matter what I do.Can someone help me with this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
arzoo arzue, Sounds like a damage LCD. Below is a guide(2nd link) to enable you to get inside device to check and reseat connections in case this is the issue. If screen still not working properly the LCD screen is probably damaged and needs replaced. 1st link is a replacement display if needed, which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
このアンサーは役に立ちましたか?
Thank you so much for your help.:)
arzoo arzue , Your welcome thanks for replying back and feel free to select answer as your solution. Good luck with your Venue.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 350
