メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Haier製ノートパソコンの修理情報および分解ガイドです。
Some keys of keyboard NOT Working?
Some keys of keyboard NOT Working ??Like N,space,ALT,B,C.ENTER key .How can i repair..If it cannot be repaired and need to changed keyboard of my haier laptop ?Which keyboard model can fit into this laptop.Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 14
15 件のコメント
faraz0920 what model is your Haier Laptop
さんによる
Haier YB11 PM Nawaz Shareef
さんによる
Hello,
We have an laptop y 11c ,its keyboard has been stop functioning because of few drops of water have spilled on it, i want to change its keyboard so that it could function like earliar..
さんによる
i have new hair laptop of prime minister and some keys of keyboard not working now what i do bro
さんによる
If it's new, take it back to where you bought it.
さんによる
10件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
I don't know this make of laptop, but for most, swapping the keyboard is fairly straightforward. You may have to remove a bezel between the keyboard and the hinge to gain access to the required screws, or you may have to remove one or more screws from the back, or indeed the keyboard may just clip in place. Then you just need to be a bit careful in releasing the ribbon or ribbons connecting the keyboard to the motherboard. You probably wouldn't be able to fix the troublesome keys in your existing keyboard.
You will need a replacement keyboard for the exact same model, and make sure it's the right language, but hopefully you can find one on eBay.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
Guys, for Haier y11c, the best option is to disable the keyboard and use an external one. The best method I’d recommend is to disable the keyboard hardware by opening up the laptop and detaching the ribbon cable. This way you will not have to put up with any funky software. You could try disabling it through a software called KeyTweak.
Other than that, replacing it might cost you around 4-5k PKR since the keyboard is chiclet-style and you will have to replace the whole panel. This is just not worth it.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
In my case, the key tweak is working very well. At least there's no need for an external keyboard now, although my first two rows are dead. I have replaced some necessary keys and also touch keyboard as well helping me out.
さんによる
コメントを追加
The keyboard is faulty and needs to be replaced to solve it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Visit following link .
https://youtu.be/AZS4osYJ_C8
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Irrevent solution.
さんによる
コメントを追加
回答を追加する
faraz0920 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 53
今までの合計 17,379
