メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PC -ER code on fridge
I went to get ice from my ice maker and water came out instead. Then the Samsung fridge made noise and code PC-Er came on. I tried pressing power fridge & power freezer for 8 seconds which cleared it but once I tried to get ice again same thing happened.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
6 件のコメント
Does your ice maker make ice?
さんによる 共有
@dede14 what model is your fridge?
さんによる 共有
Mine done same thing , I pressed ice button an PC er came up on display ! Previous evening I started the ice again as it was off as no need for ice during winter months really ! Then water started coming out of top of ice maker part ! Any ideas if the code is related to error on ice maker ?
さんによる 共有
Had the PC - C error on my Samsung RS62K62B7SL/SA after a very short power outage. To clear it I had to run an extension cord and power it from another outlet, then plug it back into the one in the fridge alcove.
さんによる 共有
I have a model # rs265tdrs when you switch from ice to water I get pc er code flashing. Help!
さんによる 共有
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
@dede14 , Dede ,With out knowing your model # this is the Info.found, from link below. Display Panel Is Showing PC-ER:
If the display panel shows PC-ER, make sure the wire harness under the top left door hinge is properly connected. Unplug the refrigerator and remove the top left hinge cover. Unhook the wire harness and reconnect it. Plug the fridge back in and if the fault code goes away then the issue is fixed. See illustrations below. The link below also has a lot of good info. for you to check out, diagnostic checks, etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://removeandreplace.com/2015/08/10/s...
画像
このアンサーは役に立ちましたか?
スコア 4
5 件のコメント:
Did this several time but always came back a day or two later
mdr438@att.net
さんによる 共有
rapmk, if you have a question, POST as a question and not a comment and include all the details of problem/make/model#?etc., so all ifixit volunteers can see and possibly give a solution.
さんによる 共有
good morning, the pc er code is still there
さんによる 共有
I have had same problem but Samsung don't no what it is .all the same old answers but no help don't no how many times. Done this can someone help
さんによる 共有
Samsung fridge has same issue. PC ER on display.
model RF 263BEAESR
さんによる 共有
コメントを追加
回答を追加する
Dede さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 44
過去 30 日: 199
今までの合計 53,251
