メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Visual Land Prestige Elite 8Qは、Visual Land社製の8インチAndroidタブレットです。
How do I do a factory reset?
Factory reset for a visual land prestige elite 8qi
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
4 件のコメント
I got a used tablet and it will not let me log in to my account to set it up and it keeps asking for a previous email that was sync to it before and I don't know it
さんによる
I accidentally hit the button for the blind I was trying to dim my screen and I hit the wrong button now it talks to me and gives me commands but it doesn't light up I can't get nothing to light up on the screen cuz I hit for the blind and now I can't get back in it to turn it to take it off of the blind
さんによる
Don't know what happened mine. It is not coming on at all. Tried all suggested fixes of holding power volume button. Does not work. How do I n reach manufacturer?
さんによる
How do I factory reset my tablet if my password won't work
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hold both volume up and down buttons together with the power button for about 15 secones, until you see the presitige logo. Pick the option: wipe data/factory reset and then select yes. When it states : wipe data complete, go back to top and choose reboot system. Navigate using volume up down buttons and select with the power.
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
What if you are locked out of the tablet how do you factory reset
さんによる
I just did what the original text said and it worked
さんによる
How about if u don't know the password
さんによる
make sure the device is off. Then at the same time hold all three down the power the volume up and down and when you see it come on release both vol buttons and then instantly press them again do not let go of the power . hold for 3 sec and then release all you welcome
さんによる
コメントを追加
Hi,
If you have access to the device functions you would go to Settings>Back-up & Reset>Factory Data Reset.
The link below is the PDF version of the user manual:
https://visual-land.com/downloads/androi...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I installed a security code and now the tablet is rejecting it. That leaves me with no way to access the tablet to reset it. Is there a way to be able to bypass this code to reset my tablet?
さんによる
コメントを追加
回答を追加する
Denise Jolly さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 10,211
