メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
The screen is blackk now
Ok, so basically, I'm stupid and I threw my phone at my desk and it made a clap sound and the screen starting going into like a gameboy type look. Then it just went black, 3d touch and eveyrhting still works I just can't see anything.
Please help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
also, if i shake the phone I hear something moving at the top area.
さんによる
コメントを追加
3件の回答
ベストアンサー
You need a new display assembly. I'm not sure how much Apple is currently charging for that. We're getting closer to this being a positive option, but I would check it out. Also this
iPhone 7 のスクリーンの交換
iPhone 7 LCD and Digitizer
iPhone 7 LCD and Digitizerの画像
製品
$74.99
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You killed the backlight. best option is to take it to apple and have them replace it for you. if its under applecare it should be free.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
what do you reckon it would be if it's not under applecare, I purchased the phone on january 2nd so I don't know if it's still under warranty or anything.
さんによる
Not sure, also not sure what apple charges. You might not have damaged the backlight and just the cable, but take it to apple and if they charge you more than $300 its probably cheaper and better to just buy the new screen here at iFixit and replace it your self
さんによる
Also, since you hear the sound, something could have broken which can be a more costly fix
さんによる
コメントを追加
Unlikely, but possible that the lcd connector has popped out. If lcd backlight is broken, again possible but unlikely, given the construction, you will be able to see the lcd display picture under a strong flood light.
If under warranty your best option is to take it to Apple. You maybe able to get it fixed for free if the damage is only internal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 151
