メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PS3スリムは、オリジナルの型番CECH-2000を持つPS3ビデオゲーム機のセカンドバージョンである。ソニー・コンピュータエンタテインメントによって製造され、初代プレイステーション3の多くの問題を修正した。2009年9月1日に発売された。
Why does my PS3 crash?
I have a 120GB PS3 slim that I bought in Scotland during Christmas 2009. I brought the console back with me to South Africa and I am using a EU to SA plug adapter. I was playing the PS3 when I had a power failure at home, so I thought all was well and flicked all the switches back on to carry on gaming. The console started up fine and everything was running as normal but after about half an hour into my gaming session the console just crashes without warning. It has been doing this ever since. When it crashes the power light that usually goes red when the console is on stand-by just stays off, as if it's not plugged in.
The only way to fix it is to unplug the cord out of the playstation and hook it back in.
Can someone please help me, my warrantee is only valid in Europe and I'm not gonna fly up just to fix my PS3.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
This seems like how my problem started, except pressing the power button will make the light go red, then again for green. Be careful - it may become more common until it will not start up at all.
さんによる
コメントを追加
7件の回答
ベストアンサー
Alternativily, you can try this procedure, at your own risk...
http://ps3slimnews.com/tag/issue/
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I actually came along that video and tried it out, and believe it not it actually helped! If you're willing to take apart your PS3 (I was, my warrantee expired) i recomend that option. Part Serve wanted R2000 for replacement fees (Around $288) which was unacceptable, the only cost I had with this was buying the T8 Security screw driver, but I later figured out that if you have a small enough flat head screwdriver it works just as well.
さんによる
コメントを追加
最も参考になった回答
I´m having the same problem. Searching over the internet, I found out that this problem is preatty usual, actually. It has something to do with the power supply. Changing it should resolve the problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's quite possible your hard drive got fried and you're having errors. If you're not sure you want to replace it, you can take it out and do some testing on it. You can use that guide to replace the drive once you get a new one.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
All of my content still loads without fault, does this still mean the drive is corrupted? Is there system files that I can't see that could be faulty?
さんによる
I don't have a slim I have a regular ps3 and it said system storage has been corrupted
さんによる
I had got a 80 gigabyte PS3 off of a friend and when I got it I put in a bigger hard drive in it are formatted the hard drive but when it is I asked to do a system update it said in the system update of 4.55 or higher so I put 4.85 on it and did the update on the initial setup it keeps freezing on the time and date it will not go any farther it freezes up anyone on here had that problem
さんによる
コメントを追加
do ps3 have a crashing problem because i have a ps3 120gb slim and i have the odd casion tht it just freezes randomly
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
do all ps3 have a crashing problem because i have a 120gb slim i play uncharted 3 nd it crashers at random can any 1 please help me 2 findout why it dose this i have heard tht the ps3 have a crashing problem
さんによる
Change the power supply
さんによる
コメントを追加
i tried everything but it does not work plz help :(
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
JfnfnjfnfdjfskkjhcjzkAlaszkxjdkskkkjcnclalaZzdmdm
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Kfmdnfnnhdjnfjnjxkkdjjnhfjkeifjkkklejjhjjksksksjffjskkkjfjfjfjjkjjdkdjfjdmkskjfjjdksksjnfjfjd
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ryan さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 9
過去 30 日: 27
今までの合計 21,924
