メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Gateway MS2285は、Gateway NV53シリーズのノートパソコンです。主な特長は、AMDプロセッサ、15.6インチディスプレイ、4 GBのRAMです。
Computer Screen is black
My computer screen is not working at all. Everything is on while the screen stays black.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
This is mainly caused by a faulty graphics card. Unfortunately this model laptop as with many other models, has what is called an integrated video card. Meaning your Motherboard and Graphics card are one in the same.
What this means is, you must replace the motherboard to replace the graphics card as they are integrated into one another. The good news is, they are REALLY cheap to buy and you can shop around for even lower prices. Just looking on eBay though you can buy one for: $49.99 as of: 4/10/2017 which is much cheaper than other motherboards.
NOTE: This answer is based on the fact you stated your PC powers up, fans come on, but display remains black. There are other causes however this is where you should start as it is the most common reason.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Can't be the Ram failing ?! I have the same problem power on but black screen... You sure it's always the Grafic on this model 2285?
さんによる 共有
@michelecian3692
Connect an external monitor to the laptop and check if you get a display showing on that.
さんによる 共有
Hi @Jayeff
I will try again sooner, give feedback later , thanks👍.
さんによる 共有
コメントを追加
回答を追加する
krystle_kellum さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 8
過去 30 日: 23
今までの合計 2,072
