メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Panasonic Vieraシリーズのテレビに関する修理ガイドとサポート。
Sound but no picture.
My Panasonic Viera tv suddenly has sound but no picture.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 17
11 件のコメント
My Panasonic TH-L55ET5K Vierra has sound but no picture, backlight is good and I would like to known the problem. The power led on the front is working and not blinking.
さんによる
I have the same issue but everything looks good and is connected and also the LED like is solid red. Sound plays but no picture and the full screen lights
さんによる
@kingkilla88 same make and model? Have you tried what was suggested in the answer?
さんによる
we have panasonic vierra TX-37LZD81 lcd tv with the same problem sound with no picture the little green on light comes on & red off thats it,suddenly happened no picture shrinkage,lines or any other warning any idea's besides the recycling centre please
さんによる
turned tv off[been in hosp a week]just tried again same,no flashing red light
さんによる
6件以上のコメントを表示
コメントを追加
3件の回答
最も参考になった回答
@rayj58 you are not providing us with enough information. We do need to at least know what model your TV is. You want to start by checking if the red power LED on the front of the TV and see if it is flashing. If it does, we need to know how many times before it pauses and flashes all over again.
First thing you want to try is to reset your TV. Unplug the TV for a few minutes, then plug it back in. Sometimes this clears any issue. If it does not work you will most likely have to remove the back of your TV and take a look at the boards. Post images of those with your question. That will allow us to see what you see. Use this guide for that. The list of possible failures includes the power supply, the main board, the scan drive or sustain boards, T-Con board and of course the panel itself. Once we know what models your TV is and if it generates an error code we can probably narrow this down.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Your motherboard went bad
needs new motherboard (screen) replacing
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Please I need help my Panasonic tv I slept this afternoon but when only sound but no picture and there is line's display on the screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ray Johnston さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 14
今までの合計 34,437
