document feeder does not work Paper does not feed
I put paper in the document feeder but it does not work. Nothing happens Paper does not feed
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like the pinch rollers in the paper feed need a bit of cleaning. Overtime the paper dust clogs the pores of the rubber making them slick so they loose tractor. Some 80% isopropyl alcohol with a cotton swab (Q-Tip) should allow you to clean off the buildup off the roller wheels. You'll likely need to run the feed a few times to gain access to the full roller.
このアンサーは役に立ちましたか?
how do you get to the rollers?
Review this Epson service manual
過去 24時間: 3
過去 7 日: 7
過去 30 日: 13
今までの合計 1,270
