メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
20回答 すべてを表示
My dog peed on my xbox one S
So far, I know the drive doesn't fully work, won't take the disk inside. It tries also to eject, but that only works if the disk is sticking somewhat out already. Any ideas maybe with rubbing alcohol before I rip this apart? I still love my dog, but %#*@.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
最も参考になった回答
daverelax, Stop charging or powering up your Xbox One S until the liquid damage is addressed correctly, as you could be shorting out components inside the Xbox. You really should take care of the corrosion that is happening inside the device from the pee/water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the Xbox One S to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the Xbox One S and see if further damage has to be addressed. Good luck.
Xbox One S の分解
Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
My dog peed on my xbox and i tried rice but dodnt work when i tried to turn it on it went off like it was on for like 5 seconds then it turned off plz i need help
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Plz help me this chrismas i need a miracle
さんによる
コメントを追加
You can use contact cleaner on the circuit boards. I use it all the time when taking apart laptops.
https://www.amazon.com/Max-Professional-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine keeps on turning off and on even after I unplugged the touchscreen ribbon. Any suggestions.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My dog peed on my Xbox and it still works what can I do I’m only 12 so if I don’t tell anyone I won’t get yelled at so can I just let it dry
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My dog peed on my Xbox and I don’t want to tell no one should I just let it dry
さんによる
No, these are electronics. If the water is inside the console, you can't just leave it to dry without doing anything about it, or chances are your console will be wrecked next time you turn it on. When that happens, you'll either have to replace some parts or get a replacement console. Most likely the latter.
You have to power it off immediately, take apart the console & clean it with 90-99% isopropyl alcohol (no rubbing alcohol). THEN you let it dry. DO NOT turn on the console until it is fully dry. Give it a few days, or to be safe, a week.
さんによる
コメントを追加
回答を追加する
daverelax さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 9,088
