Camera will not turn on.
The camera will not power up when the camera is turned on.
If the camera will not turn on make sure that the battery if charged firstly. If the battery has been on charge and the problem is still occurring, a new battery for the camera may need to be purchased.
このアンサーは役に立ちましたか?
If this has already been tried, what are other possible causes?
Tried a new battery and charger still nothing
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 902
1件のコメント
Greetings, I'm new, my problem .. G5 LCD without image, in the viewfinder everything ok and record shooting,. replaced the LCD display is the same (does not highlight image). Both the first LCD and the replacement are powered, I see led blue dot on. Could it be the flat between the mobile screen and camera body? if yes, how to replace it and where to buy the ftat? Thank you
enniodec さんによる
