メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Water Damaged and wont turn on
My iPhone was in my pocket and i fell asleep this is embarrassing but i wet the bed from drinking a lot i guess and i woke up my phone screen was white i could still see the time and everything and swipe but couldn't unlock it with my code i left in rice for the rest of day now it wont turn on at all. Is there anything I can do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Arop A , The rice would have done very little to help your phone as it is not a very good at liquid absorption, make sure to clean the rice out of all nooks and cranny's. Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. Good luck.
iPhone 6s Plus の分解
Electronics Water Damage
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Putting the phone in rice probably didn't help. Some components may be shorted internally, so you should avoid using the device or charging it to prevent internal damage. From your description it sounds like there may be issues with the display, as well as more extensive damage.
Below is a teardown of the phone, and also some guides to help with liquid damage to phones.
iPhone 6s Plus の分解
iPhoneの水濡れ・水没ダメージからの復旧方法
iPhoneの画像
ガイド
難易度:
難しい
1 - 2 hours
iPhone 6s Plusの画像
ガイド
iPhone 6s Plus の分解
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arop A さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 1,291
