メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
iPhone always turns into Recovery Mode after Display replacement
I replaced the screen of a iPhone 6s. It was reseted before I started the replacement. First of all I checked if the new Display would work so I only connected it before I installed it. After the replacement all the cables were connect (Frontcamera Homebutton:by the way I did not change the home button only the display). I started the iPhone and it boots into recovery mode.
I tried multiple times to flash the system but it always fails. While flashing the phone reboots and then the "restore" screen comes again and the software ( I tried with 3u tools and iTunes) failed to flash the system. Then i decided to flash the software without the three cables from the display assembly. It works, but when I turn it off and reconnect the cables. When I restart the phone now it boots into recovery mode. I tried it multiple times with iTunes/3u tools.
What could i do ? What is the failure?
Thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I was having the same problem as you. My iPhone kept rebooting on `recovery mode`.
However, when I have the home button flex disconnected to the motherboard everything worked normally after that.
And I am also noticing that my Home button is always sending a `Hold/Pressed` signal to the iPhone.
Though all, I am happy I have my phone working
さんによる
コメントを追加
4件の回答
最も参考になった回答
Use process of elimination. Does it boot without the front facing camera cable but without anything else? Do the same with everything else and you will get the fault. If it is the home button cable the display is faulty.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Thank you! I will try it and post my results.
さんによる
The iPhone was reseted, after i connect the speaker cable and restart it
さんによる
Sounds like maybe a fault front camera ribbon flex assembly if the phone boots up after unplugging it?
さんによる
When the plug was plugged in I'm able to restore it. If I unplugging the ribbon flex assembly it does not boot because the whole OS is missing.
さんによる
What do you mean the OS is missing? Also make sure it is the correct cable, the front facing camera is the first thing you unplug.
さんによる
コメントを追加
May I have the screenshot of the error while you are flashing with 3uTools?
Then I can get to know the reason.
And did you select the option "Retain User's Data While flashing" ?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I will when I get the error again. I know that it always happens at 19% while restoring. The phone reboots and after a while the error comes. Maybe device (-2)?
さんによる
Oh, I know many users met error -2 while flashing the disabled iPhones.
You can try these;
1. Change the usb cable or port.
2. Some users changed the battery and they succeeded in flashing.
3. Check if there is something abnormal in your drive of your PC.
さんによる
コメントを追加
I think that the extension flex cable of the home button is faulty, try to boot your iphone without the home button attached.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hehe0903 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 551
