メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2013年にVirgin Mobileから発売されたAndroidプリペイドスマートフォン。モデル番号:N800。
How to get data offbroken screen
I have 300 sound files I need off the phone but the screen is cracked beyond function. How can I get the data off?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Sibha Gourd, If not powering on because of screen, perhaps you could use the links below to replace your screen and get your phone up and working again and retrieve data. 1st link is a guide to show how to replace screen and the second link is a replacement screen assy. for as little as $15.99, which you may be able to do a search on and find for less. Good luck.
ZTE Awe スクリーンの交換
http://www.ebay.com/sch/i.html?_from=R40...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You will just need to plug it in in to your PC and go to the files of your mobile phone wich will show in the finder, like if it would be a USB.
You are welcome! :)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, thank you I tried that and nothing shows up. What I learned was in order for that to work the phone needs to be set to "mass storage device" mode which is within the phones "settings" however I can't change the settings for obvious reasons. I need a remote way to change the setting or an app that knows how to access the data without that option being set or...???
さんによる 共有
コメントを追加
回答を追加する
Sibha Gourd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 356
