2011 iMac shuts down few seconds after power on
My 2011 27'' iMac had a graphic card problem (vertical lines on the screen)
I took the opportunity and upgraded the card from 1gb to 2gb.
When I turn on the mac it start to boot and suddenly shuts off
I can turn it back on again and it happens again and again.
I tried to make NVRAM Reset and it didn't help.
I took out the power cord from the mac, waited few seconds, pressed the power button for 10 seconds, then, I pressed the power button and hold while putting back in the power cord and powered on the iMac.
the fans started to run at full speed and the iMac is running good and stable without shutting down but the fans running at full speed.
i made a SMC Reset, the fans started to run normally but the problem appeared again and the iMac shuts off.
#1 led is turned on while the iMac is turned off
- 1,2,3,4 lets turned on after few seconds
after the iMac shuts off #1 led is the only one on
i made an hardware test while on "safe mode" (fans at full speed) and i got error code: 4VDC/1/40000003: VIDEO CONTROLLER
any advice?
Thanks in advance
この質問は役に立ちましたか?
