CPU TEMPERATURE on MacBook Pro
Is it normal for a intel 2.5 gHz (turbo boost to 3.1gHz) i5 (ivy bridge) in a mid 2012 MacBook Pro 13 inch to get up to 75 degrees C under heavy load?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
A little too much for this. You can easily get rid of this problem by replacing thermal paste.
How to remove the cooler from here
Thermal Paste
このアンサーは役に立ちましたか?
First remove the fan and clean out the vent. MacBook Pro 13" Unibody Mid 2012のファンの交換
If the vent looks clean, look at the heat sink. See if there is an oily looking residue around it. It is liquid filled and can spring a leak and may need to be replaced.
ガイド
難易度:
中レベル
15 - 45 minutes
ガイド
難易度:
難しい
45 minutes - 1 hour
このアンサーは役に立ちましたか?
I did the thermal past but I broke the cable for the iSight camera oh well now the NSA will have a problem using my camera for there Optic Nerve program
100 Celsius is the limit. 75 under heavy load is completely normal.
You don’t need to replace your thermal paste. SMH.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 17
今までの合計 9,180
