メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kindle Fire、Fire、またはAmazon Fireは、マルチタッチカラーディスプレイを搭載したAmazonのAndroidベースのメディアタブレットです。修理にはドライバーとこじ開けツールのみが必要です。
orange screen no response
when i turn on my Kindle fire the kindle logo appears for a few seconds then the whole screen turns orange and nothing works, this is the second kindle i have had with the same problem, seems to be software but usb connection not working either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 11
4 件のコメント
Any luck? I have the same problem.
さんによる
My screen turned orange, but that’s not all. The real problem is that it shows a partially filled page to Register my Fire. Password missing, so I write it, but nothing happens. Is non responsive.
If I try “forgot password” it sends an e-mail with an OTP but when I enter it, again, nothing happens.
I tried to reset the Fire from the Amazon page, but it doesn't work… apparently it can’t connect to the Internet.
Can any one help?
さんによる
Mine starts up goes blue and then goes Kindle fire again then goes to bootloop
さんによる
My Amazon tablet has went orange on my screen. Everything is working and letting me do things but it is so annoying and I need help!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
swipe down from top of screen
select settings
select display
select "Blue Shade"
look down at "Automatic Activation
to the right side of the screen there is an oval with a dot to the left
Swipe this dot to the right. It will restore your screen to the normal color
このアンサーは役に立ちましたか?
スコア 10
7 件のコメント:
Thanks so much. I'm glad I came across you before I had a chance to go crazy. It was nice and super easy.
さんによる
I have to thank you too !!!!!
さんによる
Same here - usually when I try peoples online suggestions for various things, the problem still exists. Yours was simple and worked.
さんによる
Thank you!!!back to normal color
さんによる
Thank you so much. I knew how to brighten the screen but, the screen stayed orange until I read your instructions. It saved us a trip to the computer store and money!!
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Diana Osborne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 22,589
