メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Doogee製スマートフォンの修理ガイドおよびサポート情報です。
Phone not charging anymore
Hello, my X5 stopped charging. I've already tried other wall charger without any success. Problem is not the battery since it can be charged externally. If i buy and replace this (http://mobilespart.com/doogee-x5-doogee-...) will solve my problem?
Thank you guys.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
11 件のコメント
Doogee s60 phone refusing to charge,
Phone ran out of power ,after the phone will not charge ore turn on.
さんによる
my doogee x20 died and will not charge
さんによる
My Doogee s88pro was working perfectly fine till this morning when it went dead and refuses to power on
I was using reverse wireless charge when it turn off completely. It is refusing to power on or respond to charging cable
さんによる
@kankam any update?
さんによる
I was asked by Dogee to ship it to their service centre. I did at a cost of about $50.00
Now that they are done repairing the phone but hav not shown any proof they are asking me to pay $37.5 for clearance. in fact Doogee official store in aliexpress has a poor service. i am really fustrated
さんによる
6件以上のコメントを表示
コメントを追加
7件の回答
最も参考になった回答
When you say you can charge it externally, you physically take it out and charge it in an external charger right? If that's the case, it's more than likely the charging port.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi I'm looking for doogee Y9Plus recharge port
さんによる
コメントを追加
That's right, Brian. Thank you so much for the answer.
I understand that it wouldn't be the problem, but do you think that a new USB plug charge replacement would fix it?
Thanks again.
Renan
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I brought of amozon doogee mix lite had it for Xmas and now it won't charge or come on you can't even take back of it
さんによる
I have the same problem. Bought from Amazon. A few days after the shop warranty was up it suddenly stopped being able to take wireless charge. Had a few S range. All have connections problems to plug in. Anne.
さんによる
コメントを追加
Have same problem, how are you charging battery externally?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi Renan,
Fixed a similar problem with Doogee Y6 phone with a new charge board. Your X5 is likely similar. The fix was reasonably straightforward, providing you have some soldering skill, see here:
https://forum.xda-developers.com/u/repai...
Best wishes and best of luck
Ron
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got a similar problem on my y100 plus and the technician said it was because of a problem in the circuit but I don't have any details about it. I think he just soldered something in the original board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If So over phone make it very hit and no screen on what to do and what problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How to on back and what to make phone reduce hot and
さんによる
コメントを追加
I have problem for my charging pin it Brocken
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
renan_0491 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 31
今までの合計 11,533
