メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Mini 4—モデルA1550のLTEバージョンの修理ガイドです。2015年9月9日に発表されたiPad Mini 4は、iPad Mini 3の後継機です。
About to replace screen/digitzier - sleep/wake sensor
I'm about to replace my wife's iPad Mini 4 LTE's LCD/digitizer (fused). The guide says to remove the connector with 6 solder pads on it, the home button, and some posts talk about a component that affects the sleep/wake function of the iPad.
Appreciate any help with some concerns:
1.) The 6 pads that need to be desoldered and resoldered, is it better to release it with a heat gun or use a soldering iron and peel it slowly away?
2.) How do I know if the replacement screen/digitizer has the component needed for the sleep/wake function
3.) Should the replacement not have it, what does the component look like and how do we remove it? Soldering Iron? Heat Gun?
Thank you all! (m _ _ m) (kneeling)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You want to remove it using a soldering iron with a small hoof tip, at the lowest temperature your solder can handle. Using leaded solder here will make your job a lot easier. Pop a small amount of flux paste on the existing joints before desoldering, too.
I'd recommend against using a heat gun - the kind of heat needed to melt the solder would destroy the plastic flex - or desoldering wick/braid, for a similar reason.
It'd be pretty obvious if the new display assembly doesn't already have the sensor, as there will be an exposed copper pad array in that location, ready for a sensor to be soldered onto it.
This is what the part looks like:
画像
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Any idea on where I could buy a replacement sensor?
さんによる
Where in the world are you, Ryan? I'm based in the UK, so can only really make recommendations for here.
さんによる
Any idea on where I could buy a replacement sensor in the UK?
さんによる
コメントを追加
回答を追加する
greenbubby さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 26
今までの合計 2,151
