メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung製テレビの修理ガイドとサポート情報。
Green color on screen
Greenish on people and background
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
@nanasgirls4 what model is your TV?
さんによる
32 in samsung full HD 1080p
さんによる
I have a Samsung, ps43e450a1wxxu, s.n…b46h34pc704664k, green ting on all faces and background, wot do I do to fix this please, wot do I need to get
Thanx for your help guys
Keep up the good work
さんによる
コメントを追加
7件の回答
ベストアンサー
@nanasgirls4 the hue and color temperature settings in your menu regulate the amount of tint that will be displayed. The hue controls the amount of green. Try to adjust both settings to see if that decreses the green tint. In general since we do not not your TV's model number, you do want to make sure that all your settings are reset. Use your main set-up menu for that. Menu>Picture>Picture Reset If it has a system reset menu then you do want to use that. You also want to check if the green tint is on all inputs i.e. HDMI component coax DVD etc. Worst case scenarion you may have to remove teh back off your TV and take a look at the the wires on the T-Con board and see if the cable to the LCD is properly seated and shows no corrosion etc. Post some images of your discolored screen so we can see what you see. Use this guide for that
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
@guypersonthing sorry to hear that. Which part did not work? Adjusting the color? Or the part where you removed the back of your TV and checked the wiring and the T-con board? Or the part where you posted the pictures of your boards etc. You see, dont tell people to „ go &&^& yourself“. If you want some help with your TV’s issue, You need to ask a proper question and follow the advice given. Have a great day!
さんによる
My Samsung TV has green and purple coloring, I've tried soft reset, I've checked the wiring and the color, contrast function is not responding, and this is all of a sudden, what can I do
さんによる
コメントを追加
I had this issue also, and one of the cable box hoookups was in the wrong receiver. Make sure they all line up to the correct receivers. Fixed this issue immediately.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
mine is doing the same is there something I can try it's Mitsubishi DLP 80 INCH green on edge of faces
さんによる
コメントを追加
My tv was fine, but all pictures connected with my Toshiba recorder had an ugly cyan tint. The recorder is connected to the back of the tv with a scart connection. I gave this scart connection a wriggle and pushed it firmly home. CURED.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
worked for me (pushing it in more, also down) on my LN-T4069F using HDMI
さんによる
コメントを追加
I had the same problem with my Samsung led tv. Open the back panel, there is a serial cable that goes to the top of the tv. In manufacturing they twist that cable and kink it. Remove the tape and straighten the cable. Route the cable as straight as possible and tape it back down. This is what fixed my green screen issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have a Samsung Smart TV and it just did this, but only for Cable. After a quick search, I decided to try to unplug it for about 60 seconds, then replug it in. This resolved the issue for me.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have samsung 24 inch smart tv and the screen is a light green colour can you tell me how to fix it please tell me !
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I'm sure you can tell me how to fix it!
さんによる
the replies to that problem have mentioned making sure all connections are solid and secure, and correct, ie: hdmi, cable, etc. if that doesn't work, try a reset Menu>Picture>Picture Reset. If it's still not helping try unplugging it for at least 60 sec. Hope this helps.
さんによる
コメントを追加
Sneaked into a migrant hotel and swapped mine
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
We repaired our Samsung TV by unplugging it for one minute & solved the problem.
さんによる
コメントを追加
回答を追加する
Diane Hollifield さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 146
今までの合計 79,467
