メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このページにはASUS K556UAの修理情報が記載されています。このデバイスは、Intelによって製造された他のASUS Kシリーズノートパソコンと類似しており、長期利用のためのサポートガイドが含まれています。
wireless mouse not working
I have new laptop i5-556UA
I got wireless Srocker mouse
windows 10 home
plugged into USB - device manager finds it, says it working fine, even went to see about updating driver and says I have updated driver
however it will not function - only touchpad mouse works (even tried fn f9 to turn off touchpad)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
11 件のコメント
Is the dongle plugged into usb 2 or usb 3 (blue (usually)). Sometime USB3 ports act funny
さんによる
i had put brand new batteries is mine and wouldnt work. put another new pair in and it worked great
さんによる
My mouse suddenly stopped working on my OSX .
Please Help
さんによる
Hi @ Pratik Khadka,
Post your 'comment' as a new question on ifixit.
That way it will get more attention rather than as a comment on a question more than 12 months old.
Give more details, such as computer make and model number, mouse make and model number and any other relevant details that may help.
The more relevant information you give the better the answers you may get.
さんによる
How do I fix a Logitech M305 cause it isn’t working after i tried all of your peoples methods. And also Please give me robux on D1lJ1T_D0S4NJH
さんによる
6件以上のコメントを表示
コメントを追加
4件の回答
ベストアンサー
These are three working solutions, if they help you:-
Fix 1:
Remove USB receiver and wireless mouse battery for 5 seconds. After 5 seconds now reattach USB receiver and mouse battery and turn on your wireless mouse. This fix is working in my friend’s Logitech wireless mouse.
Fix 2:
1. Go to RUN (Win Logo + R) and type “devmgmt.msc” to open device manager.
2. Now find Mice and other pointing devices and find your wireless mouse.
3. Now right click on your wireless mouse and click Scan for hardware changes.
Fix 3:
If above fixes are not working for you then find a solution from the official Microsoft website.
1. Troubleshoot response failures in wireless keyboard or mouse.
2. Troubleshoot a wireless mouse that does not function correctly.
3. Mouse Troubleshooting.
このアンサーは役に立ちましたか?
スコア 14
2 件のコメント:
Hi @raichel121
FYI to save typing errors, In Win 10 press Win key + x key together and option box will appear left side of screen with direct links to Device Manager, Control Panel, Event Viewer etc. Good for people like me with fat fingers
さんによる
Fix number 1 was the ticket - and really, moving the USB receiver to another port is what did it. As soon as I did that it started working. It's like once the original batteries died that port was no longer an option.
さんによる
コメントを追加
@fischer76 A few things to check .Is the mouse turned on , check for a switch on the bottom of the mouse . Wireless mouse have off- on switches to help save the battery. Check the battery is not dead. Check that the dongle is plugged in all the way and if you have no joy try it in a different port . Go into the mouse configuration or settings and check that it is enabled .Finally test the mouse on another computer. Hope this helps
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
My mouse not working but my USB receiver are working?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
コメントを追加
Outdated or corrupt drivers can often cause issues when connecting a wireless mouse so please update your outdated driver and also check bluetooth connectivity.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
bobp さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 50
今までの合計 93,552
