head lights will not work
how to get the head lights to work.i changed the switch but still no lights
Update (02/17/2017)
how to get head lights to work
この質問は役に立ちましたか?
この質問は役に立ちましたか?
hobeck , check to see if the headlight circuit is fused, possible blown fuse. Check to see if head light switch is getting power with DVOM,(no power either fuse blown, loose plug, break in wire,corrosion,etc.), then check to see if power is coming out of switch, if power coming out of switch, check for power at bulb sockets, no power coming from switch(switch faulty). Power out of switch but no power at socket, break in wire/ bad plug/socket. Power coming from socket check/clean contacts/replace blown bulb. Good luck.
このアンサーは役に立ちましたか?
raining now but i will try your solutions later. thanks for the help
I'd like to know how best to find the fuse. I've found the run/tow 15A fuse, but can't trace out the headlights to find the fuse. It's my father-in-laws 2012 Cruise Car. Headlights stopped working when he put in new batteries recently.
I have a 2004 club car it runs but I have no headlights can’t find any fuses any suggestions
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 65,765
15 件のコメント
Hi,
What is the make and model number of your Golf Cart?
Have you checked/changed the headlight fuse at all?
jayeff さんによる 共有
not sure where the fuse is.there is no inline fuse that i can see
hobeck さんによる 共有
hobeck what is the make and model number of your Golf Cart?
oldturkey03 さんによる 共有
i have a 2005 club car & i'm not sure where the fuse is to the headligh?
steve さんによる 共有
I need to know how to fix the headlights on a STAR golf cart
sherry wade さんによる 共有
10件以上のコメントを表示
