メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
Touch Id not working suddenly
So a guy brought me his phone after he tried to replace the screen himself. When he brought it touch ID and auto brightness was not working. I checked the cable under a microscope and did not see any breaks in the touch ribbon cable.
So I then cleaned all of the connectors and tried again with the same result. I reset the phone back to factory with the same results. I then put the phone into recovery mode and did a upgrade and woola it all worked.
I gave the customer back the phone and he used it for a few days and now touch ID isn't working again and he said the screen is glitchy. He reset it back to factory and touch isn't working but the screen is working better. I had him put it in recovery and try doing an upgrade and touch still is not working.
Has anyone encouneeded this or have any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
What phone models is it? Have you tried with other LCD?
さんによる
コメントを追加
1 件の回答
ベストアンサー
My guess is a cheap quality screen replacement with a bad home button extension cable which comes with the screen.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
I agree. You'd have to try with a new or at least known good screen. After you connect his Touch ID button and install the screen, do a restore and test.
さんによる
Does it matter that it was working, and then just stopped?
さんによる
Also, I did replace the screen and did the restore and it worked. And it lasted for a few days. Could this be software related?
さんによる
コメントを追加
回答を追加する
Andrew Hogeboon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 182
