メインコンテンツにスキップ
2013年10月22日に発表され、11月12日に発売されました。iPad mini 2はRetina Displayが搭載された iPad miniとしても知られており、小サイズ7.9インチのフォームファクタのiPad Airに全ピクセルが詰め込まれています。
426回答 すべてを表示
Something is strange after replaced the screen.
I'm tried replacement the touch screen. but, it is fail. lcd dosen't turn on.
however, this will change the lcd change.
The real problem is strange in software.
iPad's power turn on. but, when turn the cover back, I hear locked sound.
Why is that?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Smart Cover being used with magnet in it? Or using magnetised object on iPad? Probably in contact with the smart cover lock sensor.
I think there is nothing wrong with the software and did you unplug the battery first before unplugging and plugging the LCD cable?
If you didn't then most likely the backlight circuit needs to be diagnosed. Might be a backlight filter blown.
Have you checked if the LCD is showing display with no backlight? I think you shine flashlight to check if it's showing very dim display.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Smart cover is sold by Apple.
It was originally intended to replace the touch screen.
When I replaced it, I cut the cable of the touch screen, lifted the lcd, removed the iron plate, removed the iron plate covering the cable of the lcd, and removed the cable of the lcd cable and the screen.
maybe, It seems that there was damage when lifting.
さんによる
コメントを追加
I'm having trouble understanding your question, but it sounds like you may be having trouble with your iPad Mini 2 screen staying dark or turning off when your cover is on it.
It's possible that the sensors in the new screen are detecting the magnets in the smart cover when it's fully opened (they're only supposed to detect the cover when it's closed). Does the same problem happen when the iPad is not in the case and doesn't have the cover?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
First, Smart cover is sold by Apple.
And only when use a cover.
さんによる
That's what I thought. That problem is often due to the circuitry attached to the home button cable - on the iPad Mini 2 that's permanently attached to the replacement glass and digitizer panel that you installed. If the sensor is too sensitive it will behave like that with an Apple SmartCover. The only way that I know of to fix it is to make sure you've got your kapton tape properly installed or, if you have already done that, to replace the glass and digitizer panel with another one.
さんによる
Also the home button cable has the smart cover sensor components on there. Either reuse the home button from the original screen if possible or transfer the small components to the other home button cable.
If the lock button only works by holding power button then maybe the home button cable is damaged.
さんによる
コメントを追加
Did you remember to Transfer the Magnets from the old Digitizer to your replacement Digitizer?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
what magnet? i don't see and touch the magnet.
The only magnet I saw was the left smart cover magnet.
さんによる
omg. i'm found it in trash after read repair guide
さんによる
yeah, sometimes they are hidden very well with black tape.
さんによる
コメントを追加
回答を追加する
qjarms1146 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 480
