メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
Upgraded to 512GB SSD, now SSD link width down to x2 from x4?
I replaced the stock 256 GB SSD with 512 GB from same generation MacBook (2015 retina) and now my SSD controller link speed and width have decreased, disk benchmark has slowed.
Is there some configuration change I need to make in order to get x4 link width and back to better speeds?
256 GB/stock SSD:
画像
画像
画像
512 GB/replacement SSD:
画像
画像
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
4件の回答
ベストアンサー
It's the part you put in is only a PCIe x2 unit not a PCIe x4 which is why the lane width dropped.
The newest version of the SSD is hard to come by and it will be more expensive. So far Apple doesn't offer it as a spare only as a swap out (you need to send the old one back) and it needs to be the same. Hopefully this control will end soon as the newer models don't use the same blade type of SSD. In any case it will be costly!
Update (02/08/2017)
Adam you'll need to get into the system profiler service to check the new SSD's firmware comparing it with your older SSD.
Open About This Mac and click on the System Report button. Click on NVMExpress and SATA/SATA Express sections, enlarge the window so all of the info on the right is visible snap a screenshot of each and post it here so we can see what each has.
As a reference review this question and what Eduardo encountered: Upgraded my SSD, Was it not suppose to keep same read/write rates?
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
The replacement SSD is from a 2015 Macbook Pro Retina and it was paid good money for (since I know they are rare). Are these not 4 lane?
Original 256gb SSD model: MZ-JPV2560/0A4
Replacement 512gb SSD model: MZ-JPV5120/0A5
さんによる
I wonder why Apple doesn't use regular M.2 SSDs. Do they really make enough prophet from replacements to justify a proprietary connection?
さんによる
Apple doesn't use regular M.2 SSDs because that standard was not finalized when they began using PCIe based SSDs in their machine. Once they had their own supply chain up it did not make sense to migrate to M.2
さんによる
But many of their pci-e SSDs are different. M.2 can be SATA based (b&m key) or PCI-E based (b-key). If their SSDs change with nearly every generation, why not just use the M.2 standardized connector?
さんによる
@pccheese - George, Apples SSD's are just different! You can't use a M.2 SSD in place of theirs.
Don't get off the subject here the focus in on why Adam's replacement Apple SSD fails to run at the same rate as the original.
The answer is: the lane width of the SSD was altered from the older models which had 2 lanes to the newer models having 4 lanes. So in a nutshell he bought a 2 lane SSD which was likely sold to him as a 4 lane.
The only other factor here is the SSD's firmware may not be for his system as it was taken from a MacBook Air which had an older cut of firmware.
さんによる
4件以上のコメントを表示
コメントを追加
I have had issues with my upgrade to Samsung 970 Pro 1TB with Sintech adaptor of lanes and sink speed dropping.
See here.
Please confirm if this PCIe SSD would work with my 2015 system
I found a reset to PRAM allowed it to return to the full 8GT/s and 4x link width.
Obviously you will not be able to get a faster or wider link than the slowest bit of hardware in your chain.
eg I put the 512GB SSD from my 2015 15” rMBP into a 2013 iMac and despite the SSD being capable of 4x it will only get 2x link width because the iMac is only capable of 2x.
Point here is for a machine that you know is capable of faster, the PRAM reset fixed my issues twice.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I believe Samsung SSDS don’t support 4K block size which is what Macs prefer since their NVME SSDs were introduced . The older 512 byte block support was retro fitted around Sierra or High Sierra but you’d be safer buying a brand that either comes as 4K or can be formatted as such using a PC firmware utility usually a boot disk.
さんによる
コメントを追加
were u able to figure out the cause? same here lane dropped after upgrading late 2013 MBP from 256GB (A/00) to 512gB (A/06)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The issue was the replacement SSD was only a two lane part vs the original SSD which was a four lane part.
さんによる
コメントを追加
is there any way to upgrade the imac2013 from 2x lan to 4x lan ?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The number and speed of the PCI lanes is very much not upgradable. It can only be slowed down by something. Find out how many lanes and what pci generation your hardware is and then try to get it to run at that speed.
Any slower bit of hardware in the chain will slow it down. It’s possible for poorly seated connections to cause the link to slow down. What I didn’t know before was that the PRAM reset could help return things to full sleed if all other hardware elements are faster and it’s still staying at the lower link speed.
さんによる
Any solution you found for this?
さんによる
コメントを追加
回答を追加する
adam.foley さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 30
今までの合計 8,100
