メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon COOLPIX S9700は、NikonのCOOLPIXシリーズのカメラです。薄型コンパクトなボディに30倍光学ズームと1080pの解像度を備えています。
How do I remove the lens
I have a mark on the inside of the lens of my S9700. I almost looks like a chip, but I'm hoping not, and can't see how that could have occured. I know how to remove the outer most cover by twisting to the left with the lens extended, and can see that the lens glass itself is suspended by the rest of the structure. There are 3 screws which seem to be holding this assembly in place, but having removed them I still can't lift off the lens structure easily, and I don't want to force it too hard in case there is something more I have missed. Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@davidsain , David, Posted a couple links below, I think if you posted at first link the owner may have a break down of lens he might send you, 2nd link are a few lens break downs/schematics that you can click on and check out the info. Good luck.
http://www.johncaz.net/blog/how-to-locat...
https://www.google.ca/search?q=Nikon+Coo...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
David Plant さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,344
