メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC One Mini 2は、2014年5月にヨーロッパ、中東、アジアで発売されました。モデル番号M8MINxのHTC One Mini 2は、リアカメラ1基と16 GBのストレージを備えています。HTC One Mini 2はHTC One M8によく似ていますが、より小型で低価格です。
Motherboard replacing from EE to O2
As in topic.
I changed motherboard in my HTC One Mini 2... and rear camera stop to working. Front camera works fine. Originally motherboard and phone was EE, now motherboard is from O2. Because motherboard was O2 I must unlock phone, I did it.
After unlocking rear camera sometimes was working, and on second day after motherboard replacing, completly stops to work.
After motherboard changing everything works fine except rear camera...
Any suggestions...?
Update (02/23/2017)
Hello,
I fixed problem with silver colored tapes. This is not a solution...
I think back cover cause problems with camera. Nothing else, just back cover. Camera works without back cover! I try find solution.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Hello,
I fixed the problem. Ribbon cable connector located at the bottom of the upper circuit board caused the problem. I changed it and now everything works fine. Step 13 "Battery" at HTC One Mini 2 バッテリーの交換 middle picture at that step.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Check the camera has a good connection to the motherboard or maybe buy a new camera and see if that fixes it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thanx for your reply. I force stopped camera and then I cleared data and cache and for a couple of times it starts to work... but just for a couple of times...
About your suggestion: camera has a good connection to the printed circuit board (PCB) above motherboard and once I replaced camera, but without success, does not work...
But... when I have been changing motherboard I did not or not seal properly three woven, silver colored tapes to the motherboard and one silver tape by mistake I cutted...
Do you think, there an important woven, silver colored tapes...
Thanx for your reply!!!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Piotr さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 20
今までの合計 344
