メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Screen problems when mobile data on
Hi, I just installed new screen on my Iphone 6s. Screen works good, but after turning on mobile data or calling, screen started to generate random touches. When I turn data off again screen works perfectly. Do you know where the problem can be?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Bad aftermarket screen. It's a static discharge issue caused by screen. I'm really surprised it happens on iPhone 6 series as usually it only happens on 5 series.
Try with flashlight on as it draws more power from the phone it will probably do the same thing.
Also try using it on the table without holding the phone and see what happens.
And what's funny sometimes you can simply stop it from happening by installing a tempered glass screen protector.
For another temp fix try lowering screen brightness with Auto brightness off.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Don't forget to discharge the phone
さんによる
I got lazy at one point and stopped doing that. I'll start doing it again as I remember having a soft bricked iPhone that may be caused by not draining residual power out of the phone.
さんによる
Tank you for response, I tried flashlight but it was ok. I noticed that the problem occurs only in some places. I can call and using data outside, but in some rooms at my house sceen goes crazy.
さんによる
コメントを追加
回答を追加する
Gusto Nemec さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 104
