Custom binary blocket by frp lock.
Enable OEM Unlocking before flashing any ROM. Flash the Stock ROM and follow this guide to Fix Custom Binary Blocked by FAP or FRP Lock.
このアンサーは役に立ちましたか?
Greetings,
do you still have the problem, if yes I got the solution and also the bypass for you :)
FRP Lock is used against thefts, before FRP exist, people could just do a three button combo to factory reset your phone and sing in with their Google Account. Since FRP it shall make it harder for people bypass this, if you do such a factory reset it will ask about the previous Google Account used (that clearly thefts don't have). Hope this helped you to clear it out. It is possible to bypass this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 16
今までの合計 3,239
1件のコメント
gianimiliardaru0 exactly what does this "Custom binary blocket by frp lock." mean? what do you see? What does it do? It will help if you clarify this.
oldturkey03 さんによる 共有
