Where does spring go?
where does spring go in manual stapler
この質問は役に立ちましたか?
Eric Fields , I assume you are asking about the long thin feed/load spring which usually connects to a small tab on the staplers upper slide housing and to a tab on the slide. The links below should help you out in seeing spring mounting locations. On the guide link once you have opened it you can zoom in on where the spring is attached. Good luck.
このアンサーは役に立ちましたか?
here we describe everything ..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 10
過去 30 日: 95
今までの合計 44,579
2 件のコメント
Where can I buy a spring for a nematic staple gun thanks Mary
Mary Fallon さんによる 共有
This doesn't work for swingline 444
Izaakraaaaay さんによる 共有
