メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Apple製品で使用するために設計されたピコプロジェクター。
no projection or light
Continuation has the purchase of a cinemin swivel, I have a problem:
When I switch on the pico connected to an ipod, an image is projected with the cinemin logo; but two seconds after, nothing more no projection or light which goes out of the device.
By looking the lens I has fault sees a small light at the bottom of the device
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Any fix for this problem with the swivel?
さんによる
nyl777, it would work so much better for you if you ask your own question and give as much detail as possible if you are expecting any help with your device. Your two questions on ifixit actually show up as answer to older questions. Click on the link on the right hand side of this page, where it says" Ask a question" Give it a try, it is not difficult and you may get some help for your problem. Good Luck.
さんによる
コメントを追加
4件の回答
ベストアンサー
Sounds Like a the bulb has burnt out. Hopefully its not to expensive.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
How to be safe that It is the bulb, because the device does not have was used
さんによる
He reacts in the same way when no device is above connected
さんによる
コメントを追加
Are you using it with an iPhone, iPod, or iPad? Because if you are, you need to use the little adapter. It should plug into the charger port of the iProduct, not the headphone port, and then the 3.5mm plugs right into that. I had this same problem, until I noticed the adapter lol
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It may be the cord or the adapter. Sometimes, I have to plug my DVD player white into the yellow, and the yellow into the white in order to get the picture. It's like a crossed wire or something.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
画像
Does anybody know where I can find the blue cord that connects the cinemon swivel 8410 projector component with the battery component?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
specie さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 3,236
