メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2008年発売のネットブック。モデル番号:ZG5 AOA150-1691。8.9インチ画面、1.6 GHz N270 Intel Atomプロセッサ搭載。
Motherboard problem, broken track.
Hi, my background is in electronics but found working on micro=electronis without circuit diagram difficult. Took this on as a favour for a friend. The DC socket was badly damaged such that the pin on the motherboard was so slack that I thought the track would be damaged. Sure enough I got a new DC socket fitted but still not charging up, there must be an open-circuit from the through-hole plating to the first component (probably pull-up resistor) the charging LED that emits when the Mains charger is fitted. Need to find out from circuit diagram or motherboard where the central pin is linked to. Can anyone help?
Update (01/26/2017)
Just realised my typing error! Should read BROKEN TRACK!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
I think that this is what you were asking after.
http://www.s-manuals.com/pdf/motherboard...
It is from this link.
http://www.s-manuals.com/notebook/acer_a...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Hi Jayeff, the first web page didn't make much sense but certainly the second came up with required schematic. Will need a good magnifying glass now to identify the capacitor as my eyesight has deteriorated since working at component level on PCBs fifteen years ago. Thank you so much for your input and I will let you know how I get on ... Frank.
さんによる
コメントを追加
回答を追加する
Frank Alexander さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 320
