メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Cosmos 3(モデル番号:LG-VN251S)は、LGエレクトロニクス社製のスライダー型携帯電話です。
sd card not working
I got a micro sd card inserted it with the phone off. It won't reconize it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
If you have a Windows computer, attach the SD card to there, open file explorer, right click on it, select format, then click the file system type drop down menu, then select fat from the list, and hit start format. Put the SD card in your phone, and it should work. Hope this helps!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
you may have to format the sd card which will unfortunately erase everything on the card. or the card may be corrupted which means you need a new one anyways.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Its a new micro sd card. I went to format it and It says I need a phone lock code number. I don't know what that is. its not the voice mail code.
さんによる
I did use the last 4 numbers for the code but it still shows the memory is full.
さんによる
I still can't figure it out. I formatted the 16 gb card (it shows I have a lot of memory available)and then restarted the phone and it still shows inbox full. I don't know what to try next.
さんによる
By playing with it I moved all info from the phone to the card and it still shows the inbox is full so I kept playing with it and transferred all info from the card to the phone and it still shows inbox is full. Any ideas?????
さんによる
I talked to LG and they said that there is no way to save texts on this or any other phone. They said that the internal memory and or the sim card is fixed and that's that. The sd card is for pics and music.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
golf0473 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 873
