メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Chromebook C710-2847は、GoogleのChrome OSを搭載したAcerの低価格ネットブックシリーズのひとつです。デバイスの構造はシンプルで、分解にはドライバーが1本あれば十分です。
Is there a Screen switch?
Recently started having problems with the screen turning on/off intermittently. Opening the screen sometimes it goes blank, fades or screen is all grey. Noticed that if I grab the right corner near the hinge and squeeze upper and lower halves together it comes on. Also noticed the screw at that corner holding the halves together is stripped. Is there a switch in there that activates the screen when opened. I cannot remove the stripped screw. It is stripped in place and will not come out. Any help would be appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I believe you would have to replace the LCD, I've had this issue in the past and I believe that's what I did. There should not be an "LCD Switch" and as for the stripped screw, I would try using a flat heat. I use two methods of removal of stripped screws. I either solder something into the screw and then remove it or I Dremel a pattern and unscrew it with a flat head.
I'm not sure if this helps but good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dennis Damico さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 390
