メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年4月に発売されたHuawei P9 Liteの修理ガイドとサポート情報。
Reboot loop after replacing Display
I replaced the broken screen on my Huawei P9 Lite, everything went fine, the display is working.
Problem is the device is stuck in reboot loop now. It restarts as soon as de Huawei Logo appears. I already tried launching into EMUI and made a factory reset - didn't help.
I don't understand what could have caused the issue?
Thanks for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
6件の回答
ベストアンサー
The back facing camera was the problem. I detached all flat cables and tried attaching them one by one. As soon as i attached the back camera the device wouldn't restart though.
I'm still wondering what is wrong with it, or how I damaged It while replacing the screen but at least I know what was the problem.
Thanks a ton richard for your help!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have a problem with my phone is it's stack on a Google account.i don't remember it please help
さんによる 共有
コメントを追加
have you tried the old screen? if old screen allows normal boot, problem is with lcd or digi IC on the new part.
Update (01/26/2017)
if you have access to a microscope id check for any parts that have come off the board. if you have another board to compare with it would be good. i suppose you could try to flash the phone with a rom and see if that makes any difference.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
hi, thanks for your answer, i just tried the old screen as you suggested. but the problem also exists with the old screen. any further ideas?
さんによる 共有
コメントを追加
最も参考になった回答
what is your battery voltage? and are you sure the power button is working properly?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
the battery voltage is 4.4V as far is i can tell (the NFC sticker is glued to the battery). i'm sure the power button is working correctly as i can power the device on and off as well as access the factory reset menu etc.
さんによる 共有
コメントを追加
I have same problem without mean camera the device working but with camera boot loop help pleassssss
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my p9 lite it just go on and off itself i dont know anyone help plz?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi all,
I have substituted the display and the battery of my P9 lite and got the same problem: the phone turns on and is stuck in the Emui recovery mode where three options appear.
  1. Reboot system now
  2. Wipe data/factory reset
  3. Wipe cache partition
Nothing changes even after trying all three options. It just comes back to this screen.
I will try to pin point the problem to see if it's the battery or the screen or the camera (??)
. I'll let you know as soon as I can.
However, if the problem is the camera can someone explain why?? And how to fix it ?
Thank you everyone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sebastian Marschall さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 25
今までの合計 6,521
