メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
charging port is broken
Hi, my iPad Air 2 is not charging, it is completely dead. It is missing a charging port 7th pin (L1p, lane 1 positive). When I plug in the charging cable it doesn't show the "battery" logo, nothing. I have tried the force restart, nothing. Is this pin need for the charging, if I change the charging port it working fine again? Thank you. Atti
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
more likely then not if you are missing a pin then that is the problem. the charger needs every pin in order to charge your device properly. replacing the port would then if the missing pin is your problem, fix your issue. i hope that this is helpful and you are able to use your tablet again soon
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you so much. I will change the charging port.
さんによる 共有
コメントを追加
I know it’s been a year since you posted, but I have this same problem with my now retired air 2. (Which the wife now uses)
i found that that if I could position the adapter at the iPad just right, it was updated “connnect” and take a charge. It’s annoying, but it works…
I’m tempted to do a tear down on my own to check it out, see if something’s come loose but with the repairable factor at 2/10 not sure I wanna delve into a complicated repair.
dis you ever get this fixed? Was it the charging port itself? Something else?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Attila さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 22
今までの合計 3,426
