Front camera blurry and light leak from top corner after screen repair
I just repaired an iPhone 6 and used an iFixit front panel full assembly, screen worked fine however in the dark I noticed heavy light leak from the edges and also the front camera was blurry. Any suggestions as to a cause of this problem? And what is the recommended solution?
Thanks
Blurry front camera. Clean front camera lens and glass cover.
Ben さんによる
is the frame bent regarding the light leak?
richard さんによる
No, the frame is not bent at all.
Stelios Sgoutas さんによる
I get the same light leakage from beside the volume buttons nearly every time, I've tried checking for bends in the frame, I even used new frames and OEM parts but it still happens. Am I doing something wrong?
S2i さんによる
