メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoogleとHTCが共同開発した8.9インチタブレット。2014年11月に発売され、Android 5.0 Lollipopを搭載。
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Just a quick update, my new battery arrived today, fitted it and booted first time.
さんによる 共有
Yay!!! Glad your phone is back to working condition :)
さんによる 共有
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
さんによる 共有
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
さんによる 共有
コメントを追加
最も参考になった回答
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
さんによる 共有
コメントを追加
回答を追加する
David Jackson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 28
今までの合計 572
