メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Aspire E1 シリーズは、台湾の新北市に本社を置く電子機器メーカーである Acer, Inc. が製造・販売するノートパソコンのシリーズです。Acer Aspire E1 シリーズは 2012 年に発表されました。
Computer says No bootable device?
When I start up my computer it says no bootable device. How do I get it to start up windows?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I recommend you watch this video https://www.youtube.com/watch?v=B4nVdq2n...
さんによる 共有
コメントを追加
4件の回答
最も参考になった回答
First check in bios for hdd
If its shows hdd then tymry to install operating system using bootable pendrive
For more details visit www.omcomp.in
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I recommend this video https://www.youtube.com/watch?v=B4nVdq2n...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I've faced this issue before and I tried know 4 different methods. There are several reasons that can cause this error. I cant explain every step in detail but I think anyone who is facing this issue would be able to understand or you can read this article: Fix No Bootable Device Error (Thoroughly explained)
One of the following step will sort out the problem:
1. Are you using a tool to make your removable device bootable? If not, then create a bootable Windows 7 USB device via Rufus.
2. Restore the Operating System
3.Using following CMD Prompt:
bootrec /fixmbr
bootrec /fixboot
bootrec /scans
bootrec /rebuildbcd
4.Re-Install or Reset Windows
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Either your lucky and a wire is loose, (power, or ide/sata) at drive or mother board. Or the more likely. Dead hard drive. This happens more often then you'd think. Drive may still spin up and make noise also, it just doesn't access data any more. You can usually tell this when it makes a repeated pattern of clicks. This is the drive head trying to find it's starting point to put it plainly. Anyway, unfortunately , if it's the later you need a new boot drive and a Windows restore disk. You can use about any size drive you want, this is where people often use smaller SSD drive for fast boot and add another slower but Huge data drive for media. You can usually get a system restore disk from the manufacturer of your computer. If not available there are instructions to how to create one on the windows website, using another computer to create a bootable USB that will load everything needed to your new hard drive. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Adrienne Ryan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 7,692
